WE 300B is long gone. If you find anything cheaper than $3000 PER TUBE consider yourself lucky. This was the first tube to disappear completely.
Quality 12AX7 is much more scarce than 12AU7 which is rather plentiful. 12AX7 is high-mu tube used in different applications than 12AU7. TU-8200 is not designed for 12AX7, don't try it. And biggest improvement to TU-8200 sound comes from swapping out 12AU7 for 12BH7 or better yet E80CC. Read up on it in this thread, don't just do it because those tubes have twice as big plates as 12AU7 and require more heat to stimulate emissions over larger cathode.
Instead of building other amps I stuck to this little gem, made it excellent, made sure I have lifetime supply of awesome tubes and then got a spare amp kit
In my mind you get better results by focusing on a good platform like this and making it perfect rather than trying to screw around with multiple amps.
I will keep that under advisement. I just ordered the EL34 to give a listen. Given reintroduction of 300B I may build 8600 just because of the cage to protect tubes. I am using a rack with 8U locking door to keep my daughter out.
