EricP
- Oct 29, 2004
1) This thread is not meant to be a rehash of the "skeptic's challenge" wherein someone says "cable upgrades are useless lol"
That out of the way, what is the technical explanation for why a cable upgrade can improve the sound? For instance, there are many who would laugh you out of the room if you suggested that adding a different cable to the HD650 would make it sound differently. I was one of those until I got the Zu cable, and while the difference isn't night and day like some would make you believe, there is a small audible difference in the sound, and I'm curious as to why that is the case.
If you do not have a knowledgeable (and scientifically correct) technical explanation, please refrain from gibberish.
Thanks,
Eric
Thanks,
Eric
