aos: Good point! I should reiterate, then, that I meant my comment to apply only to the topic of audio amplification, in which I feel it is most practical to not attempt to incorporate circuit parasitics, rather, to swamp or avoid them.
eric343: the point of audiophilia is the reproduction of
sound, not square waves. Square waves are composed of the addition of the odd harmonics to a fundamental in the proportion of one over the harmonic number (the third harmonic would be 1/3rd the level of the fundamental, the fifteenth would be 1/15th, etc.) This is known as the
Fourier Transformation of the square wave, btw, and keeping it in mind will go a long way towards tempering your thirst for bandwidth and slew rate
To keep your square wave looking reasonable requires that the rise time not take up more than 5% of the period (we'll assume that fall time is the same, for a total of 10% of the period spent in transition). 5% of the period of a 20kHz square wave is 2.5uS. To convert this into bandwidth, you can just take the reciprocal of the period: 400kHz. And, mind you, your amp's response must be flat out to this frequency.
Now what do you suppose are the chances your CD player - in which a brick-wall filter chopped off the signal at 22,050Hz somewhere along the way - will be producing 20kHz square waves accurately? Sorta takes the breath away to look at it from this perspective, doesn't it? But don't feel dejected, virtually nothing on the planet you'd want to listen to generates a square wave, which is why, along with the above explanation, I think banging square waves through an amp is good only for testing its stability.
edited because I just saw aos' post and wanted to say: cool link! I was looking for something like that to illustrate my point!
edited again because I couldn't resist tossing one more jibe eric343's way... hehe. Quote:
Besides, if I can get my amp to reproduce a near-perfect square, then at least I'll know it will reproduce perfectly anything else that I throw at it |
A 7404 Hex inverter will do the same thing, but I wouldn't want to use one as my headphone amp!
'Course, there was that link awhile back that had a CMOS hex inverter chip being used as a headphone amp... maybe not so crazy?
Tomo ought to know
