groovyd
- Jun 29, 2012
Just throwing this out there to see if anyone else has tried the latest El Capitan Public Beta and is having any problems with their USB audio devices as a result of it? For example since the upgrade my McIntosh D100 is dropping 1 second of audio every 15 seconds as connected through an Anker Usb 3.0 async capable powered hub. It happens from any audio source, iTunes, Safari, Skype, JRiver, etc... and so basically you cannot listen to music with it because every 15 seconds it cuts a second.
I am hoping this is a problem for other people with other gear because if it is just me then I doubt I will ever see a fix for it come down the pipe.
What it seems is happening and this is just educated speculation is they changed the USB driver or have some process scheduled to wake every 15 sec and take full priority over the bus for a second. If this is true I would have expected to see the same pausing for disk transfers but I have not looked that closely yet. Other possibility is that I can no longer set the Clock Source in Midi Setup to using the clock provided by the D100 but it is now only set to 'Default' or the clock of the mac itself which is probably totally out of time with what the DAC requires to fill its buffers on time. So maybe a specific audio USB driver issue and related to the async devices?
Anyway, please pipe up if you are having similar audio issues under El Cap. and hopefully we can get some consensus on this.
