Yes I did. BA works fine actually but with Kr 300B, not XLS.
After few mails and tests with Craig, it appears that maybe the 300B XLS made by kr don't work fine. The problem (maybe) was a thermal contact issue with the output transistors. They are clamped to the bottom plate if one of the four transistors is not tight, or does not have enough heat sink grease it may be thermaling out causing a drop in power. And the Kr 300B XLS need 1.8A filament current and the BA was designed for 1.25A filament Current : maybe it's to hign currrent for use them with the BA for long hours of listening and make warm up too hign the power supply unit
It's only a supposition, after make warm down, BA come to alive and my friend use some Kr 300B normal version with no problem for long hours.
Also, note that Kr 300B Xls isn't made to replace standard 300B, electrical characteristics are too different, EML 300B xls are designed to replace all standard 300B, it's noticed on eml site (and note on Kr Audio site). EML need 1.6A filament current 300B XLS (1.2 for a standard 300B).
i hope you'll understand my translation.
