- Aug 2, 2008
This is for the two to three people in the world who are interested in the mod to run PX25 tubes.
The Eddie Current BA in its current iteration runs PX4 and 300B tubes. The heater voltage is set to 4V for the PX4 and 5V for the 300B. In addition, there is a switch on the back of the amp. The UP position is for PX4 and the DOWN position is for 300B. After the mod, the UP position will be for PX25 and the DOWN position will be for PX4 (or 300B).
The mod requires x2 of this part: http://www.mouser.com/ProductDetail/IRC/GS3-100-5600-JLF/?qs=XjRxj70TXJJMO6iKOGoRcg%3d%3d It's a 3 watt 560ohm resistor.
There is a 470ohm resister that sets bias current for the PX4. For the PX25, this resistor should be 250ohms. So basically we parallel it with a 560ohm resistor with the 470ohm to get ~255ohms. Here are the steps:
As an aside, the switch in the DOWN position puts in series an additional ~ 300ohms (or 270ohm in this my particular amp) to run the PX4(modded) / 300B (unmodded) in the circuit. The UP position basically shorts this connection for PX25(modded) or PX4 (unmodded). Craig mentioned that after mods, we should be able to run 300B's in the DOWN position - I guess things were set pretty conservatively.
So a recap:
MODDED (total resistance in circuit)
PX25: 255ohms (470 | 560)
PX4 or 300B: 525ohms (255 + 270)
STOCK (total resistance in circuit)
PX4: 470ohms
300B: 740 ohms (470+270)
Don't forget to set voltages for the 4V tubes properly!
Next post will be the adapters if you don't have the Yamamoto multi-sockets.
- Remove all tubes and connectors
- Flip amp over
- Unscrew 8 screws on the bottom cover
- Here is a zoomed out view for some perspective
- Here is zoomed in on the 470ohm resistor (in the middle.) It's brown and in series with the black 270ohm resistor. Note that the mod is already applied with a 560ohm resistor to the right next to it and in parallel with the 470ohm. (Excuse the extraneous leads and solder - I had initially tested the mod with RatShack 1k and 2k ohms in parallel.)
- Repeat on the other side / channel
So a recap:
Code:
-----560-----+ | -----470-----+-----270----- #====PX25====# #====PX4/300B=============#
PX4: 470ohms
Code:
-----470-----+-----270----- #====PX4=====# #==========300B===========#
