Gilly,
I forgot to ask will the explorer support MQA?
Thanks,
Claus
Thanks,
Claus
Gilly,
Thanks,
Claus
We definitely want to integrate MQA in the future
Gilly,
Thanks,
Claus
I think the future of MQA is streaming services like Tidal.
Without wishing to derail the thread, MQA smells of DRM to me. It's not initially being released under that guise, but it's a very small step to use the built in authentication for DRM purposes. Anyway, time will tell...
What the hell is DRM? It sounds like the devil!
I can see that being the case. What I really want to see is the ability to convert my library to MQA, without DRM. I want the equivalent of HiRes mp3. If it isn't going that way, I will happily let it play on Tidal, Spotify, Deezer and the like. I don't want to have to rebuy my library, nor should I be expected to.
@Gilly87
Does the Echobox have ALSA incorporated in the OS?
I'd like to be able to use it with the ALO Continental Dual Mono, which uses ALSA for its DAC. At one point I could connect my android phone to that amp with a OTG cable, but the phone lost that ability somehow.
Heya,
The Explorer doesn't currently support OTG; it has a digital coax output, but no USB OTG at the moment.
We're working on getting 5.1 up and running, which may help with OTG support before launch, but I can't make any promises right now.
