Easy headphones but with sound quality ..
Jun 10, 2018 at 6:29 AM Thread Starter Post #1 of 24
JediMa70
Italy
I m just trying to find something easy to drive like them but with a good sound to use for my walks and while i do stuff at home, because HD600, HE-560 and AKG K712 are not really really an option for that and meze 99 classic (these 4 are the ones i own) are not ready to be messed with my sweat
What would you reccomend under 100 usd? (can go a little higher too..)
Jun 13, 2018 at 7:46 PM Post #3 of 24
Couldn't find them here in italy
Jun 13, 2018 at 9:02 PM Post #5 of 24
Check out a SoundMAGIC HP151. Maybe read about it and see what you think. It might work for you.
They are fantastic, i'd love to buy them but here they cost so much
Jun 14, 2018 at 5:11 AM Post #11 of 24
Hey thank you! so many options I will take a look at them and see which one can be good for me
Jun 16, 2018 at 12:32 AM Post #13 of 24
Koss Sportapro would be a perfect fit for what you need. These literally changed my life. For $30.00, too!
Jun 16, 2018 at 5:57 AM Post #14 of 24
In a way I like them a lot, very cheap too, didn't think that sounded good, I was considering ATH M40X but now you are two here mentioning those koss
Jun 16, 2018 at 12:31 PM Post #15 of 24
Koss has come out with a new headphone, the KPH30i, which has great reviews. It's $30.00, too. It should sound similar to the Portapro and Sportapro however it appears to have more of an open air sound.
The KSC75 has been acclaimed by many over the years. The titanium driver is supposed to be highly detailed and sound like very expensive headphones. It's an ear clip type but is only $20.00 or less. I will try the KTXPRO1 (same titanium driver, different housing and with headband) as the Ksc75) soon and post on the forum my opinion.
