Earwax and Sound Frequencies?
Aug 20, 2021 at 4:47 PM Thread Starter Post #1 of 5
EternityInParis
Canada
Does earwax have any effect on sound frequencies? Does it have any sound absorption properties? Could some reviewers find a headphone veiled because they have build up? Others find it sibilant because they have none? Stupid question I know. Thanks.
Aug 20, 2021 at 9:03 PM Post #2 of 5
Earwax reduces transmission of the higher frequencies.
If you take the nail on your thumb put it under the nail on your ring finger, and make a sound by quickly flicking the thumbnail, you can hear a high frequency noise. Do this before and after having your ears cleaned by a doctor, and you will really notice the difference.
Aug 20, 2021 at 9:09 PM Post #3 of 5
It turns out that wet wax reduces sound transmission more than dry wax:
From https://www.jscimedcentral.com/Otolaryngology/otolaryngology-3-1087.pdf
Results: Wet cerumen caused considerably more hearing loss in all grades of occlusion compared to dry cerumen.
Conclusion: To standardise the results of further studies on this topic, a uniform classification of the grade of external ear canal occlusion needs to be developed.
Aug 21, 2021 at 6:23 AM Post #4 of 5
Thank you for this pdf. Almost everything was relatively easy to predict, but now instead of intuition and educated guess, I have actual data. Which always makes me happy.
Aug 21, 2021 at 6:47 AM Post #5 of 5
