iarmstrong
- Jun 25, 2012
TEMPO EARBUD
[size=10pt] Actually i do not know too much about earphone or headphone technically.[/size]
[size=10pt] As per your reviews and support rating i think it is best place to open Questions to get required answer Which will help me for further Solutions[/size]
[size=10pt] AM currently using sansa clip plus 8gb and i am interested to buy earphone[/size]
[size=10pt] from given two orders[/size]
[size=10pt] First one is[/size]
[size=10pt]Philips[/size]
[size=10pt]SHM3100U[/size]
[size=9pt]philips Notebook headset SHM3100/97[/size]
[size=9pt]Features[/size]
[size=10pt]· [/size] [size=9pt]Highly sensitive microphone[/size]
[size=10pt]· [/size] [size=9pt]Neodymium magnet[/size]
[size=10pt]· [/size] [size=9pt]Optimal ear bud size[/size]
[size=9pt]Specifications:[/size]
[size=9pt]Sound[/size]
[size=10pt]· [/size] [size=9pt]Frequency response:[/size][size=9pt] 12 - 20 000 Hz[/size]
[size=10pt]· [/size] [size=9pt]Impedance: [/size][size=9pt]16 Ohm[/size]
[size=10pt]· [/size] [size=9pt]Maximum power input:[/size][size=9pt] 50 mW[/size]
[size=10pt]· [/size] [size=9pt]Sensitivity:[/size][size=9pt] 106 dB[/size]
[size=10pt]· [/size] [size=9pt]Sensitivity microphone:[/size][size=9pt] 80-15000Hz, -42+/-3 dB[/size]
[size=9pt]Connectivity[/size]
[size=10pt]· [/size] [size=9pt]Cable length: [/size][size=9pt]2 m[/size]
[size=10pt]· [/size] [size=9pt]Connector: [/size][size=9pt]2 x 3.5 mm[/size]
[size=9pt]And Second One [/size]
[size=9pt]JBL Tempo Earbud [/size]
[size=10pt]JBL Tempo Ear-bud High-quality Earphones[/size]
[size=10pt]Features:[/size]
[size=10pt]· [/size] [size=9pt]Comfortable fit earbuds-foam cushions included[/size]
[size=10pt]· [/size] [size=9pt]15mm dynamic drivers for clear, full-range reproduction[/size]
[size=10pt]· [/size] [size=9pt]Powerful, clear JBL sound with exceptional bass[/size]
[size=10pt]· [/size] [size=9pt]High-performance 15mm drivers[/size]
[size=10pt]Specifications:[/size]
[size=10pt]· [/size] [size=9pt]Frequency range:[/size][size=9pt] 20Hz-20kHz[/size]
[size=10pt]· [/size] [size=9pt]Impedance:[/size][size=9pt] 32ohms[/size]
[size=10pt]· [/size] [size=9pt]Sensitivity:[/size][size=9pt] 113dB[/size]
[size=10pt]· [/size] [size=9pt]Max Input Power:[/size][size=9pt] 4mW[/size]
[size=10pt]· [/size] [size=9pt]Cable:[/size][size=9pt] 1.2m(3.9ft)[/size]
[size=10pt]· [/size] [size=9pt]Plug:[/size][size=9pt] 3.5mm (1/8") [/size]
[size=9pt] so which one is best as per technically point of view[/size]
[size=9pt]Technically specs affect sound performance quality such as ( [/size][size=9pt]impedance:[/size][size=9pt] 32ohms vs 160hms) or power input mv [/size]
[size=10pt] Max power input does drain efficiency of battery ? flows ? continuously (4mv jbl and philips 50mv)[/size]
[size=10pt] Which one is better ? as per your suggestion.[/size]
[size=10pt] your time is really important for me [/size]
[size=10pt] thanks[/size]
[size=10pt]iarmstrong[/size]
