Davesrose
- Oct 20, 2006
And if people read the article, they'll see you're cherry picking!! The whole paragraph says that was one of three options for improving on the previously developed PCM-1. From that article:And I supported that argument by quoting Sony themselves who stated they had: “to develop a brand new way to directly record the digital audio signal onto an optical disc, instead of using a video signal from a video recording format.”!
"Encouraged by Nakajima's enthusiasm, Toshitada Doi and his colleagues joined the development team and began work on constructing a smaller and cheaper recorder. One of the group members, Akira Iga, had an inspiration. The frequency band used to reproduce video images was more than 200 to 300 times the frequency band of analog audio. Theoretically, this would be sufficient to record the large amounts of information necessary for digital audio. Iga wondered what would happen if he tried to make a digital audio recording using the Betamax home-use VCR, launched in 1975. Nakajima had him try immediately.
Nakajima and his team designed a PCM circuit that would perform large-scale signal processing in order to allow Betamax to record and play back digital sound rather than video images. This was called a PCM Processor, and it appeared to hold great promise. A VCR and a PCM processor used in combination constituted a digital audio tape recording system. This system was displayed at the 1976 Audio Fair and attracted considerable interest."
And you're still skating around the content of the Wikipedia article that says 44.1kHz became the basis of CD due to early PCM encoders recording on videotape (it's the second paragaph). If 44.1kHz is always the obvious choice for a digital audio format, then I guess all those other formats you listed that weren't 44.1kHz, or that the DAT standard also supports 48kHz, was all for giggles.No I’m not! I’m clearly saying a CD standard was required that was as low as possible but above 44kHz, so even if TV broadcast standards or videotape had never been invented, the standard would have been set around 44.1kHz anyway but due to the fact in the wiki article YOU posted “44,100 is the product of the squares of the first four prime numbers () and hence has many useful integer factors.” and also that it’s the max supported rate by the PAL TV broadcast standard, it’s an obvious/sensible choice.
G
I think you now denying that you didn't say video standards were a factor for 44.1kHz is a good example of how you're so tied up with arguing for argument sake. Usually it's semantics, now it seems to be circular reasoning. People would read video formats being a factor when you say: "The obvious choice would be one of the two most common TV broadcast formats." (BTW, it's 2 of 3 video formats)
And with that, I'm finished with this flame war.
