Davesrose
- Oct 20, 2006
No, as I said, US TV broadcast is AC3 (not AAC). Broadcast TV in the US adheres to ATSC standards, as outlined in every version (version 3.0 is coming online and addresses UHD resolutions/color space).Exactly. Tv is the brain, in my opinion too, Gregorio, because it provides the decoding. There is no need for AVR when you downstream downmixed PCM audio. I am simply pointing out, that downmixes executed in the brain (TV) sound better then source stereo track and that through ARC they sound better in my system then via Optical and I also tried to explain why it might be so.
AAC codec is mentioned in signal information of TV, Davesrose. Perplexity says it is quite common in digital broadcasting to use AAC codec for audio.
https://en.wikipedia.org/wiki/ATSC_standards#Audio
Don't rely on AI: it scrapes data from the web-which can be data that's not correct. I just encountered that when I tried Googling IMAX Enhanced with Nvidia Shield Pro (one of my streaming devices-the most capable for passthrough audio). Google AI said Nvidia Shield is supported for Disney+ DTS IMAX Enhanced. I had to reference a few sources to see that it doesn't work with NVidia because Disney uses an uncommon profile for lossy DTS. Apparently you have one of the few TVs that support it-and most brands aren't rushing to support it because there's only 22 whole movies that have this non-standard lossy DTS:X track. I would be able to rip an IMAX Enhanced UHD and still retain the IMAX metadata within DTS-MA DTS:X, and it would passthrough to my receiver that supports IMAX. But most IMAX Enhanced movies on UHD are IMAX movies (not blockbusters). You may be hearing what I've found when I compare a movie in DD+ Atmos vs TrueHD Atmos-the TrueHD track usually has a higher level (I turn my volume down -5%, and I notice there's a higher LFE level as well). The difference isn't their formats-it's how the tracks were mastered.
Again, it's only a few streaming movies that are IMAX Enhanced (a DTS stream) and they also carry a DD+ Atmos track for all the brands that aren't Sony, Hisense, TCL TVs. If you're selecting each of those tracks, they're different mixes. It's not the format! Also, since it's only 17 Marvel Movies on Disney+ that are DTS IMAX Enhanced, you're up a creek if you refuse to listen to all the other streaming and TV content that is AC3/EAC3.One thing I may have exaggerated is the DTS HD MA 7.1 thing. It says English DTS and English Atmos in Pictures Core audio track selection settings. DTS sounded better to my ears.
