Sam L
Ok, fine. You win, from now on.Come on, it's not that hard to add a single line of codeNow I sound like a programmer.
Now I have to make a version for myself and another one for the general public. Lol
Why? Don't do this. I think this line of code will automatically skip when loading if EQ doesn't recognize itOk, fine. You win, from now on.
Yes bro ! Don't work! Samsung S8 plus with sonata hd pro . Right ?Thanks for sharing. I'll put together of a list of hardware that doesn't work with wavelet at some point.
Also, USB direct mode will not work with wavelet. So some apps will require that to be disabled before wavelet starts working.
**edit**
have you tried just the sonata hd pro with your phone? I just confirmed that the sonata hd pro works with wavelet on my Samsung s21
I use UAPP for TidalIf you use Poweramp, you have to disable DVC for wavelet to work
Don't know if other music player need some adjustment like this.
no toes stepped on... It's a great tip to make things easier for users. Also, in Peace any pre-amp values entered can also be saved as well.Why? Don't do this. I think this line of code will automatically skip when loading if EQ doesn't recognize it
Also I posted it as a tip for those who don't want to set up a non-stop preamp value every time they load the preset.
I had no intention of sabotaging your "miraculous" workSorry if I caused a problem
BTW...I sent you a PM.
Take your time. Let driver to break-in a few days. With daturaPro don't expect quantity in bass but quality. DaturaPro will probably have more balanced sound then Tomahawk.Just got my Datura Pro. It sounds terrible without EQ. With EQ it sounds better.
Still taking some time to compare it to my Mrz Tomahawk. I'm not noticing a giant improvement in sound quality though. Sub bass seems tighter and less distorted. Sub bass quantity seems lower even when using 1.5 bass PEQ.
You confused me with the previous comment. You didn't tell me right away that you tried them without foams.After messing around with the bud I think I am satisfied with it.
First thing that helped was putting on the foams so it was more secure. The bud is a bit smaller than the mx500 shells that I am used to so it keeps moving around my ears and not creating a good seal for the bass.
Then I changed the bass reduction at 200hz from -15 db to -10 db. Without this boost, it sounded kind of tinny to me compared to my other buds.
Now that I've listened to these buds I think I can hear sounds that were distorted on my other buds. The improvement is somewhat subtle, but I guess I was expecting too much since I was expecting a massive improvement like going from $10 to $30 buds.
I'd definitely recommend these buds over all the other ones I've had if you don't mind using an equalizer. It sounds better than my tomahawk with the tweaks I made. There's no overly boosted treble, and imaging seems better as well. Though it should be noted you might have to get an amp since you need to reduce the volume by -10 db in the equalizer.
ahh... Yes you have to run my files with foams on. I compensate them assuming that foams are on the buds.After messing around with the bud I think I am satisfied with it.
Thanks.@Sam L
Is this the last file for Rambo II?
https://www.head-fi.org/threads/earbud-target-curve-tests.944006/post-15966086
By the way, what a great work you did with Rambo II !
I can't tell any difference between foams and foamless on my other buds. I'm just using them on the datura pro to get a tighter fit to my ears since they are smaller than what I'm used to and the buds keep moving around my ears.
I'm not noticing any changes between the original and 10k files either. I think the treble is fine.
If you look at the FR curve here, it looks like by boosting the drop at 200 hz by +4 db, it would make the curve flatter across the entire spectrum, so I guess I prefer a very neutral curve.
