dsavitsk
MOT: ECP Audio
- Aug 3, 2003
I am stumped. I made a small PCB in Eagle -- It is very small and simple and has about 15 components on it.
When I try to make gerber files (first running excellon.cam and then running gerb274x.cam) the drd file (the drill file) does not match up to the other files. When I open it in GCPreview, all of the gerbers are very small with the drill file very large.
I am only having this problem with this one board -- other boards seem to be working okay. Also, I copied these board files to another computer and had the same problem, and I recreated them from scratch (both the schematic and the pcb) and still had the same problem. Even weirder, it worked yesterday.
So, can anyone offer any suggestions as to what the problem could be? I did modify one library component, but even removing that part has not helped.
The offending files can be found at http://www.ecp.cc/HVPS2.zip
Thoughts?
-d
Thoughts?
-d
