- Feb 3, 2017
Yes, to my ear there is quite a significant difference between the Shangri-la vs. Shang Jr., more than I expected actually. They're both voiced neutrally in the Hifiman style, but I made the analogy that if the Shang Jr. is a great bookshelf speaker, the Shangri-la is its companion full-range floor-stander. The Shang Jr. rolls off in the bass too much to convincingly convey music with significant bass energy.Almost most of the people here cannot have afford the Shangrila Sr., is there a huge difference between the JR and the SR?
Soundstage I suppose is larger on the Sr?
From my recollection, the Sr. soundstage isn't necessarily wider, but it is a bit taller. You're sitting even closer to the stage with the Jr. than with the Senior. The Senior's imaging is also tad more pinpoint. Some of these differences may be dependent on amp and chain, of course. I recall being a little farther from the stage when listening to the Junior on its dedicated HFM amp vs. on my home setup.
I wouldn't take my impressions as definitive, but hopefully they are of some use anyway.
