amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
The current limit resistor is a part of the OPA541 design. The resistor, in conjunction with circuitry inside the opamp, prevents the OPA541 from self-destructing in case of short circuit or other overcurrent conditions. Have a look at the OPA541 datasheet and answers to your questions are all in there.
For the most part, yes.
The OPA541 is rated for continuous 5A current maximum, but you must also take into account the power dissipation and heatsinking requirements, etc., so in practice, current-limiting to a value less than the maximum with a bit of margin is the prudent thing to do.
The dynahi's PSU is really not designed to be a speaker amp power supply. You should either consider using a separate PSU for the gainclone, or go with a PSU that could supply much more current.
Originally Posted by bg4533 What is the point of a current limiting resistor? Wouldn't it be best to just let the PSU be limited by the OPA541? |
Since current is limited it seems logical that the PSU can only take advantage of a certain sized transformer. Is this true? |
What is the max size that can be taken advantage of given the .2ohm resistors? How about .1ohm resistors? If I am to use a transformer with a current rating of 5A does this mean that without the current limiting resistor the PSU could output 5V? |
I am considering integrating the Dynahi with a Gainclone or even using the Dynahi to power speakers directly and think I need more than 3A power. |
