nekromantik
- Jul 30, 2009
some of those taobao links dont work anymore.
trying to use pandabuy but it does not load it
It won’t download from ibasso - for me at least - sticks on 12.9mb. Can’t be done via the system updater either. They’ll sort it..Has anyone managed to get it to work? Why doesn't the "Updater" detect the new firmware? I tried downloading it and then a local update via the "Updater" - it didn't find the file at all. So I tried moving it to the root of the file structure and it could see it, but still fails to update.
I just downloaded from their website and did a local update and the process went smoothlyIt won’t download from ibasso - for me at least - sticks on 12.9mb. Can’t be done via the system updater either. They’ll sort it..
You have extract the files from the zip file and then place the extracted zip file in the main directory of the internal storage. Then go to the update screen and click on the 3 dots in the top right corner, select local update and then select internal storage, it will then see the zip file and install the updateHas anyone managed to get it to work? Why doesn't the "Updater" detect the new firmware? I tried downloading it and then a local update via the "Updater" - it didn't find the file at all. So I tried moving it to the root of the file structure and it could see it, but still fails to update.
This worked for me. The “updater” doesn’t work though.You have extract the files from the zip file and then place the extracted zip file in the main directory of the internal storage. Then go to the update screen and click on the 3 dots in the top right corner, select local update and then select internal storage, it will then see the zip file and install the update
Ok, sorry, where is the update screen, rather than the updater? Many thanksThis worked for me. The “updater” doesn’t work though.
In the system settings - go to system - click on updater and follow @buckster666 instructionsOk, sorry, where is the update screen, rather than the updater? Many thanks
