ozz007
- Mar 2, 2012
Can you add the numbers on the volume bar? I would like to know what percentage of the volume I'm listening to. Just showing the bar when I turn the wheel is not cuting it.
I just downloaded it from the link you show. No issues.Keep getting a error while trying to update.. "failed to update"..
Extract dx260fw-ota-v2.01.zip to get DX260_full_ota_2.01.307.zipKeep getting a error while trying to update.. "failed to update"..
Where can I get one? And do they make it in black cause I'm BatmanThey match now
What ever you get used to . I find it extremely easy to use.The Mango player is so badly designed, I install Hiby music player instead. Happy listening.
I think Mango sounds best on these but for anyone that would like it smoother etc, just try a different player or filter. Hiby is a nice option for those that want it with a little less leading edge or more ability to modify the character.What ever you get used to . I find it extremely easy to use.
My DX260 just came in the mail yesterday.
The Google Playstore app isn't there. Worse, I can't seem to figure out how to install it. I open chrome, search for "download play store," and a window pops up asking me if I want to install playstore on other devices, and there's no option to download it to the DX260.
What now?
Thanks. It worked. But I don't remember having to use APKPure for my other Ibasso devices. I believe that it came with it.Use APKPure to install Google play, then delete APKPure if you want to.
That will be a google thing, incompatibility with newer Android, limited device numbers or wrong logon. The 1st thing I would check is if you've logged into the correct google account. I've seen this happen when somebody has more than one and spaced on which to use.Thanks. It worked. But I don't remember having to use APKPure for my other Ibasso devices. I believe that it came with it.
Now I have another issue. I installed Google Play. It found 3 local apps to update, but even after signing into my google account on Play, it is not finding any of the dozen apps I have on my DX170 and DX320. How do I fix that?
Update: I even tried doing "Send Apps" from my DX320, but it only gives a choice of a few apps to send. What's going on?
Update #2" I tried "syncing" all devices. Nothing.
