Ozric
- Sep 4, 2002
A quick question for the tech gurus...
I just installed a new 160 GB HDD as Slave in my stock Dell (P4 2.66), with the Master drive being the 80 GB Maxtor that the PC came with. There's a problem transfering data from the old drive to the new one; it's taxing my CPU almost 100% constantly.
I checked the properties of the IDE controllers in Device Manager, and while "Use DMA if Available" is selected for both channels, the Current Transfer Mode shows up as PIO for "Device 1" under the Primary IDE channel.
Is there anything I can do to enable Ultra DMA transfer, and what does Device 0/1 refer to?
Thanks!
Thanks!
