gregorio
- Feb 14, 2008
Many of the original responses were incorrect. There was no difference in LFE level between DD and DTS, or equalisation or directionality difference. DD had different audio compression presets which could be stored in the DD metadata, was more heavily data compressed than DTS and was typically played back by AVRs at a lower level than DTS. DTS did have a much better data compression ratio and was audibly slightly superior but most of the difference people thought they were hearing was purely down to the level difference. One responder mentioned THX but THX isn't an audio format. As far as consumers are concerned it's just means a piece of home cinema equipment has passed THX quality standards. In cinemas, THX is a completely different thing, it provides installation/construction standards, such as the amount of baffling between speakers to aid speaker separation. Another responder mentioned cinema sound being crap, the sample rate of DD being inferior to DTS and using your ears. Unfortunately, that responder's ears appear to have been working in reverse, there was no difference in sample rate between DD and DTS and cinema audio was superior to both because DCP only supported uncompressed wav 24/48 (no DD or DTS). Although in 2003 some cinemas were still using 35mm film but even so, 35mm film DD had a higher bit rate than the consumer version of DD.
Today, the situation is far more complex. There are numerous different formats/codecs covered by both DD and DTS and making sure you're comparing apples with apples is not as straight forward as it was 15-20 years ago. Depending on the individual AVR, the codec and the format chosen within that codec, DD can be better than DTS or vice versa.
G
G
