Here some pics.
Good day.
Hi, this might be asked 10000 times so excuse me if so..
i wondered about how this would be balanced? balanced as in same amount of cable going to each cup ? since balanced in recording industry means something different. witch is a really nice feature but not so much useful if you talk way above line level voltages with very short cable lengths. no offence just a question.
I just see this often mentioned and i wondered what peopel mean by balanced in this case.
still looks very nice ! like the mini xlr's !
This is the old meaning of balance physicaly = when used doal sided connection at the same time.Hi, this might be asked 10000 times so excuse me if so..
I not have the dt990 but the sound much better because the quality of the cable.What are the results like?
Balance connector amp the signal to to + (hot) channal and invert the second one to - (cold).
on the other amp that receiving this two singals just compare them both and clear the noises from this comparison.
Headphones that got that balanced connector just double the volume/power that they got.
So for example, my Aune x7s amp specs shown: https://www.auneaudio-europe.com/index.php/aune-x7s-class-a-headphone-amplifier-black.html
Output power on RCA max: 250 mW at 300 Ohm. (unbalanced)
Output power on XLR max: 1000 mW at 300 Ohm.(balanced), 4 times stronger!
on headphones It cant prevent any noise but it makes the amp much stronger/powerfull.
He explains about microphones/mono plug of XLR 3pin
I made such mode to, and planned to make this headphones doal sided too.
Balance inveted for studio recording quality, and brought to the audiophills as a feature to take from them more money.
And the storage with out the cable much easier.
The connector may fill stiff and not flexible if you touch the headphones with your shoulder, I plan to tilt the connection a little bit to the front on my dt880
May I ask, do I need an extra ground wire for the right?![]()
Today, I replaced the original attached cable by a connector. At the same time, I take the chance to make this guy balanced.
Here some pics.
Good day.
