Hello, novice here!
I recently got myself a Beyerdynamics dt990 pro (250 ohm) and was wondering whether i was powering them properly. I'm mainly using them at home on the desktop.
The 990s not only sound higher, but some songs and scenes changed to the point where they are unrecognizable to me. Generally it feels like the "body" is missing a lot of the time. And the sound also doesn't always seem very clean, though that might have more to do with lousy files and whatnot, because sometimes it sounds pretty good. Over all though they still sound much better.
There is that infamous sibilance but still, these highs are also pretty addicting to listen to. When trying to EQ i wanted more bass/body and less sibilance, but after doing so i started missing the clear highs too. I don't seem to know what i want.
To get to the point: Why is it that my cheap usb soundcard can drive the dt 990 pros? Do i just not like the sound of these cans or are they not properly driven, and how do i even tell the difference?
I did hear that these cans are supposed to sound good/decent even just plugged to the PC audio, so i'm not sure.
If anyone has any experience listening to these with and without amping please do tell.
- I'm not using an amp currently, but the sound i get is more than loud enough in music players, and is acceptable in youtube/videos although sometimes i need to max the volume.
- But I am currently using a (don't laugh) Speedlink Vigo. It's one of those small external USB soundcards, as my mainboard doesn't have onboard sound.
