Frederose
- Aug 21, 2014
I really don't understand the aversion to EQs too, I just rockboxed my Ipod and, with the new EQ it sounds really good, way better than before.
So everybody mentions that the 990 have an annoying treble spike (and God knows it's true!), but isn't it trivially easy to tame with an equalizer? Isn't it easily dealt with when you bring down the 8K bar? I noticed that it takes eq rather well and I don't hear much of the music being lost as a result.
Thank you, and that's how I feel about eq too. So much is written on Head Fi about how eq distorts sound and should be avoided at all cost, that you almost feel guilty for using it. It's not like we are trying to change sound across the board; just a little trim on that small treble bump. Do I really have to buy HD 600 just so I can avoid using that little eq on the DT 990? I don't think so.
To an echo an earlier sentiment in the thread, the reason I prefer not to have to EQ hps in order to "correct" the sound is because you're limiting the flexibility of those EQ options. The DT-880 is more neutral and sounds great without equalizing. What's great is that I can now play with the EQ settings to bring out interesting details in the music given the genre or recording. You're otherwise limited in this regard if you constantly have to guard against fatiguing/unnatural treble frequencies across most (if not all) of your music.
I'm glad I'm not the only one who thinks a little eq won't ruin the music.
I wonder though what's behind the desire to hear classical music only from flat, neutral headphones (two of the biggest contenders being DT 880 and HD 600). Say you're listening to a symphony, don't you feel that even though the 880 gives a neutral, flat presentation, the 990 allows you to experience the music in more vibrant colors, especially in the way it brings out the bass - perhaps the most essential element of the performance? Bass can be quite enjoyable for classical music as well, can't it? I don't see why flat is in such demand for enjoying classical works. The chest-pounding sounds from the double bass section, the roaring trombone and all that low frequency gold is one of the most delightful sounds that a symphony orchestra produces. Add to that the wider sound stage and increased instrument separation, and you might look at DT 990 a bit more favorably when it comes to classical.
I don't want to push a discussion about the 880 vs 990 differences in classical too much toward a discussion of how to make them similar (even if it's completely doable). The op started the thread to highlight sonic differences inherent to each ear phone's physical design, and has been very patient with these side discussions on eq. I'll knock it off.
The general assumption with neutral presentations, especially in classical, is that ideally your trying to get closer to the recording or the way it sounds live. Neutral is the most logical choice to get that, since we can only assume that the recording guys were after a neutral response, the mastering guys were after a neutral response, and now if you go for that neutral response you should be hearing roughly what they did. Does that mean you have to be an absolutist and stick to dead neutral? Of course not, but that's the theory anyway.
In regards to classical bass specifically, I personally don't like a mid bass hump. If you gave me the choice to emphasize the initial hit of a drum or the low rumble that came after the percussion, I'd personally choose the rumble. I enjoy having the low bass with classical because it translates to fuller sounding organs, cellos, and bass. Remember that by emphasizing one part of the band, we lose emphasis elsewhere. So a flat response in the mid/upper bass will retain details in the low bass.
There is always a lot going on in a classical mix. At any given moment, there's strings, woodwind, percussion, even choir voices creating a wide spectrum of sound. Classical listeners tend to prefer neutral because it allows them to approach those frequencies from the perspective that they are all equally important and deserve equal emphasis.
Edit: Not mid-bad hump, mid-bass hump. Damn swift key.
Doesn't really matter if it's an upgrade, technically. What matters is that they are very different, and that for that reason alone you might greatly prefer one over the other.
Oh, by all means, let's talk about that too. Making 880 and 990 sound similar... And it's completely doable you say? I want to know all the details, especially about making 990 sound more like an 880 (just so I know what it is I have been missing).
These headphones fascinate me and I don't get tired reading about them. Strange obsession, if you consider how many other interesting things there are to abscess about in this world. But, ultimately, I think it's about music. We want to maximize the enjoyment we're getting from the works we love so much. That's my justification for spending so much time reading about cans.
