schul105
- Sep 17, 2014
Hi guys,
I just joined the forum after much searching and deliberation and need some advice on what I should do,
I've been looking for a my first pair of high quality headphones and initially settled on the Audiotechnica M50x's however returned them as they just weren't comfortable enough.
After this I ordered a pair of Beyerdynamic DT 770 80 ohm and a Fiio E07K to power them and use as a DAC, however the shop accidentally sent me the 250 ohm set.
Therefore my question is, should I stick with the 250ohm set, or send them back for my originally ordered 80 ohm set? To my ears, the 250 ohm set sound pretty great, however, will the E07K provide ample power to bring out there full potential, or it still be under powering them?
If so should I swap for the 80 ohm set or buy a Fiio E09k to combo with my E07K to provide ample power? Would the extra $100 be worth it?
From what I have been able to learn from the forums, it seems the 250 ohm has a larger sound stage, which appeals to me greatly, however the 80 ohms have more bass (better for electonic music).
Some other info, I'll mainly be using these to listen to music (everything from classical to rock, pop, electronic etc), I'm also a casual gamer, hence a larger sound stage is advantageous in this regard.
Any help, advice and insight will be very appreciated!
Thanks!
(P.s, loving the forums!)
Thanks!
