tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Yep - R4/R5 are the only RN60 resistors on the PCB. Tough to get those mixed up.
OJNeg's help is greatly appreciated. I agree that the CCS appears to be the issue. Just for kicks - and this would be my fault - can you check the labels on the Q3 and Q4 transistors? Make certain that they're "2N5087" and not "2N5088." Also, check the MJE350's while you're at it - ensure that's what it says ("MJE350") on the front of those transistors. I have tons of different transistors that go into Beezar kits. It's possible I might have got them mixed up.
Q3/Q4 are correct, they are 2N5087, I am not sure about MJE350 yet, I need unscrew those first and check, I will update later today.
thank you all.
Unscrew them? If you can't see the writing on the outside, then they're installed backwards.
