D-Panda's arrived today.
Unboxed, put on, been listening.
Doing that now.
Have shuffled through Jazz, Disco, Acoustic, Folk, Hard Rock, etc.
Prior to listening today to these, ive been listening to Sundara's, Elex, Aeon X, and HD800S.
When i first put these on, they clamped a lot and felt north of light, but as ive worn them, they relaxed toward semi- comfort, except for the headband.
Its always an adjustment to go from one listening context to a different one, as in Open to Closed.
So, if that is ever your case, you have to give your ears time to figure it all out.
Mine have figured it all out now, regarding the Panda.
I dont want to call them "Drop Panda", as who wants to drop such a cute and cuddly bear?
Verdict?
Well, im using them with a Matrix mini -i3 and the volume is -47.0 and that Killer Gear is making these sing.
Also, i never use wireless, i always use wired.
And, as i reviewed these prior to purchase, some reviewers that seem to know what they are doing... concluded that the Wired
and Wireless sound, is exaclty the same.
Normally the wired is better, but in this case, as these reviewers loved the wireless sound, i was ok with the purchase.
I could not tell you if the wireless sounds the same as wired,.... as i wont be using these without a wire.
What my ears can tell you is that these are adjusted by the engineer/design team to sound neutral, natural, and especially good for voices.
Mids are about .5 stepped up, which is a good thing.
Overall....
The Panda's sound is engaging and pleasant.
Panda Timbre is honest and good.
Bass is fairly detailed, and at least one step back from the Elex and the Sundara, so, that is 3 steps above the original bassless Aeon Closed.
These are not bass canons, but don't give up yet....
Mids are good and slightly wet and dialed in for vocals as i stated.. They are not shallow, scooped, or veiled.
The midrange tonality is pleasing.
Overall Treble is more rich than airy, and definitely not as sharp as the recent HD560S.
The Panda is a good value for its Price, and the headband is unfortunate as it does not have enough padding.
This can be modified for pleasure........no biggie.
