crippledchicken
- Jul 15, 2004
Would there be anything to be gained sonically by putting the shorter 6xx cable on the hd 660s phones? I assume, the cables are interchangeable? Thanks!
I'd say any audible difference would be highly unlikely.Would there be anything to be gained sonically by putting the shorter 6xx cable on the hd 660s phones? I assume, the cables are interchangeable? Thanks!
Best thing is download APO equalizer and the Peace front end. In it is a hearing test where it takes you through test tones (make sure it's a quiet room) and builds a custom profile to compensate for hearing in each ear. Free and takes a few minutes, but really worth it instead of guessing to get equal balance manually. Also if it's just certain frequencies, the custom profile will really help.Kind of what I thought, I may have to get another head amp If I can find one with a balance control I think my hearing is a little better in my left ear.
