morfic
- Nov 11, 2008
Cobalt is a alloy content of the HSS bit (makes it withstand more heat), Titanium refers to the coalting TiN TitaniumNitride (makes it withstand more heat until you wore through the coating, also changes how chips stick to the drill).
Both can be worth it, and if you want to resharpen bits (No, drill doctor is no good) Cobalt (uncoated) would outdo coated plain HSS in the long run.
Consider carbide when you do pick up a drill press and small vise.
For PCB drilling you could set up a Proxxon in a drill press attachment, as long as the drill only moves up and down and not "sideways", carbide is hard to beat for many many many precise holes.
Originally Posted by junkie2 /img/forum/go_quote.gif For starting DIY, what sort of drill and drill bits would you guys recommend? I plan on starting on the CMOY and then moving on to a PIMETA and PPA or a M^3. I just want a basic mid-low end drill for now. I'll consider a drill press later on. From what I hear, I should avoid Black and Deckers; anything else? What drill bits do you recommend? Are cobalt or titanium necessary (what are the difference, and is there a preference)? |
