Dublo7
- Jul 5, 2007
So I've used DVD Explorer to extract the 5.1 files from this Porcupine Tree in Absentia DVD-A. However, when I downmix these WAV files to Stereo (using Eac3to) there is a lot of hiss on the resulting files. I've used this exact same method to downmix around 5 other DVD-A disks without issue, but this one is causing me a bit of grief. I'm suspecting the problem is to do with the LFE and Centre channel.
Has anyone here successfully downmixed In Absentia to Stereo? How did you do it?
Cheers!
Cheers!
