Originally Posted by slowpogo /img/forum/go_quote.gif
I have been using a TREAD with 24v AC-DC wall wart to power my PIMETA. The other day I was sorting through some old junk, and found a nice 30v, 400mA regulated power supply that was for an old computer printer I don't use anymore. It's the kind that sits on the floor, has separate cables for the wall socket and the device.
The plug is actually compatible with my amp. I was initially keen on using this printer PSU so I could try running the amp at 30v.
There is no reason to believe you will gain anything running a Pimeta at 30V instead of 24V. THat is, unless you have some very unusual high impedance cans that need this extra 6V swing on the output.
But what happens when you plug an already regulated power supply into a TREAD? Is it dangerous at all, or will the power just be that much more "regulated"? |
What are you talking about? The 30V 400mA supply isn't already regulated, it's a bog standard wall wart, a transformer then bridge rectifier and capacitor, not regulated. The question is just non-applicable.
I could only get about 27.5v out of the wall wart. Now I know it's safe; will the power running the PIMETA actually be *better* with this dual regulation? I mean, will it be closer to STEPS performance than TREAD? |
There is no dual regulation. Hooking up a 30V wall wart after the tread will result in (30V/110V * 24V =) 6.5V. There is no purpose in doing it.
Also, Steps is not that much better than tread, the difference is in steps having more ac filtration "IF" you need it (Not everyone does), and steps being self-contained instead of a separate wall wart. For a Pimeta, frankly a Steps is overkill.
From what I can find the supply is definitely linear, but nowhere does it say whether it's regulated or not. It's more than twice the size of my 24v unregulated wall wart, if that means anything. |
What supply is definitely linear? A 30V 400mA printer PSU isn't linear. It's just a basic wall wart as described previously, whose input to the printer is then later regulated in the printer.
Presuming you have the Tread and are using it, there is no reasonable further stage tacked onto it to power a Pimeta. The next improvement OR change in sound would come from different Pimeta opamps, different pimeta buffers, or different amp entirely. PImeta just isn't a fragile amp that succumbs much to PSU noise in the first place, with it's opamps having feedback and good PSRR, and having a ground channel, it is more immune to PSU noise than practically any other amp (topology).
