glunteer
- Sep 15, 2012
Following the thread, and waiting for the final project to buy one
running off a dedicated USB PCI on my desktop without other devices connected, into either a B22 or QRV-08, and AD2000 or modded T50RP headphones, the ODAC is etched, bright, rough and harsh. makes the BM DAC1 i recently sold after 6 years of enjoyment sound warm, smooth, and analog. with the Doodlebug inserted, less bright/etched and more fleshed out. more details and more natural sounding. still not my cup of coffee, but the Doodlebug is an improvement in my rig.
maybe my desktop USB power really sucks, or the implementation of the secret sauce Sabre is black magic. either way, isolation and clean power brings improvements.
huge props to A_A and tomb.
from a build perspective, the pads are generous and require a little extra heat. high quality board and a perfect first time SMD project.
I guess the ODAC's perceived brightness bumps the HD650's subdued highs, which is probably why people enjoy the objective stack + HD650's.
I've recently installed the output booster mod on my O2, which has made it more "musical", I can imagine that with doodlebug working on the ODAC, the changes would be noticeable on my setup.
Count me in as an interested patron, whenever the next batch is ready!
Out of curiosity (question open to anyone knowledgeable), would it be of any benefit to put a ferrite core on the cable from the doodlebug to the ODAC?
This project looks super cool. I'll probably build one for my PupDAC. I recently built a DAC that employs USB isolation and it sounds great. A few questions...
1) Is there a possibility of using external battery power with this? If so, what would be required?
2) This one might not be able to be answered yet... For the guys who use a Gamma 1/2 is there a benefit to this being that it already has the option for an external 5v supply?
1. Sure, you'd need a battery capable of maintaining over 9V at whatever current your USB load is going to draw, for however long to want it to work - so likely something fairly hefty.
The power supply on the doodlebug in it's current form won't be overly efficient for battery use. It will draw 10-20mA or so through the LEDs depending on the exact devices and where you set the output voltage. But with some component changes you could get this down to 1-2mA at the expense of possibly raising the noise floor a tiny amount.
2. It depends on whether or not an isolated ground will give any rewards. Some computers (especially laptops) have noisy ground rails and this will get into the analog output of your DAC if it has the digital and analog grounds connected. If there isn't a problem with a noisy ground, or ground loop(s), then a full USB isolator shouldn't offer any benefit compared to power only, everything else being equal.
2. I'm treading on very thin ground here, because I respect AMB and all of his designs. However, to suggest that the ground is noisy, but the voltage side is not, seems a bit of conjecture. If the noise exists, the voltage side is always referenced against the ground, so there's no way that one would be "contaminated" and the other not. (They both come through rectification equally to form the DC plus and minus references.)
There is some support in the conjecture when it comes to PCB layouts that convert AC to DC. In those cases, I agree that as little of a connection to ground from the AC side to the DC side is best. However, the connected ground is always less noisy than the non-connected ground. I speak from experience in the months and months of experimentation and measurements that Colin Toole and I did on the Millett Hybrid MAX and MiniMAX designs. The original completely deleted the ground plane. Later versions connected the ground plane. Finally, ground planes that were minimally connected had the least noise. We went from most noise (no AC ground plane) to less noise (ground planes contiguous) to least noise (ground planes minimally connected).
In the case of the DoodleBug, we're talking about cleaning up DC that already exists, period. Trash is on both sides of the voltage differential.![]()
EDIT: As you may see from my future posts, I think the difference lies in the sophistication of the DAC. For instance, does the design depend on numerous regulators throughout the design, or is everything sort of taken as is, and the basic performance of the DAC chip implemented as simply as possible? I think the small testing I did shows that sophisticated DACs can make very good use of the DoodleBug for a greatly increased performance. On the other hand, those DACs that are simplest in nature (simplified DAC chips, very limited onboard regulation) don't have the resources in the circuit design to take advantage of the DoodleBug.
No. IMHO, that was a Band-Aid patch on the ODAC to cover up the misfortune that it was designed without any power capacitors. There is no electrolytic capacitor on the ODAC.
I'm think you may have read way to much into my post, I'm a bit confused by your reply.
If were talking about non-bus-powered DACs then only the ground is connected, not the 5V. The doodlebug will simply provide an isolated ground, which will only help when there's an issue. (not talking about internal grounding schemes at all)
Thanks![]()
I'm also interested on the "spikes" found on the 1k mark on the charts "dynamic range" and "THD and noise" for the doodlebug tests. I'm quite new to reading these types of charts and can't quite make sense of them.
Realize also that there's been debate in the past about whether to connect the USB shield (and connector) through the cable to the DAC's PCB ground. I thought perhaps some of that was implied in your post, too.
Oh, that's a very exciting project. Great to see the objective measurements backing up the theory. I'm blown by the improvements made by this simple circuit. (forgetting the complexity of whatever is inside the chip.)
But it seems a bit counter-intuitive that simpler DACs will see less improvements than more complex ones. One would think that DACs with better PSUs would be less affected by the quality of their supply. Unless it's not a matter of clean supply, but supply overload or outright data noise.
Have you tested it with the grubDAC? I'm curious if this would improve the performance of a grubDAC+Carrie.
I think simpler DACs probably have nowhere to go in performance. Not to insult everyone's favorite cheap tube amp, but it's sort of like the Starving Student. Once the inherent noise in the tube circuit exceeds the switcher power supply, there's little performance gain achieved by substituting a better power supply.
Beezar is moving this month. Unfortunately, all of my GrubDACs are packed and I can't get to them right now.However, I suspect the results would be somewhere in-between that of the SkeletonDAC and the pupDAC, because the GrubDAC has an onboard regulator.![]()
