Avro_Arrow
MOT: Soundwerx Designs
- Apr 8, 2010
The boards look good.
I should be able to get one together next Friday
or when I get a board...whichever comes later.
Any reason not to use smd rectifiers also? Should make a quicker and cleaner build.
could you say what wallwart you are using please
I can easily change to SMD rectifiers.
I had no compelling reason to use one over
the other and 1N400x are cheap and plentiful.
The isolator is designed to use pretty much any AC or DC adapter
working at 6 VAC up to 9 VAC @ 1 A. It has a bridge rectifier and
regulator on board.
Here is an example
