Tomo
DIY tube amps can be SHOCKING
- Jun 22, 2001
Hi,
I am thinking about launching another adventure. This time with some power opamps like LM1875 or LM675. I believe if driving at low power, these chips will operate at Class-A.
The subject will only drive low impedance headphones. Thus, the gain can be very low.
(Input offset current is large, but I can connect something like 1kohm bypass. So I will forget about that.)
The problem with these opamps is that they are not unity gain stable. And, with some gain, these can blow the heck out of headphones. I found this as alternative to Multi-Loop.
Tomo
P.S. Can you post the Multi-Loop Schematics? I could use one for the record. Thanks.
Tomo
