if i would have a xlr 4pin cable on a headphone, and use a xlr 4pin to 1/4 adapter, am i losing anything, like sound quality, or is this perfectly fine?
i think using any adapter degrades the sound quality. whether it is noticeable or even audible is a different question. that i don't know. i suspect that whatever degradation occurs is very minor. i have a number of Bal to SE adapters and things sound fine with them. whether the headphone would sound better if the cable was strictly SE, i don't know.
either way, sometimes convenience is just too important.
Worst thing that will happen is, the adapter adds a tiny amount of resistance to your connection.
Same as closing the volumepot on your amp a thousandth of an inch or so.
Edit: Stupid me, false statement. I thought the adapter was placed between source and amp.
But anyway: Use an undefective adapter, and you're fine.
Well...kinda depends on your confession, voodoo-wise.
From a technical viewpoint, there's no reason why someone should pay 80$ for it imho.
I own a few of the crappiest adapters you can buy, which piss me off because they may fall appart when you unplug the connection. This sucks.
Don't go "cheapest", go "reasonable". If you ask me, that is.
Originally Posted by Vul Kuolun /img/forum/go_quote.gif Worst thing that will happen is, the adapter adds a tiny amount of resistance to your connection.
For fun I measured a couple 1/8" to 1/4" adapters I had, from approximately where the jack and other plug would contact the sleeve (ground). With a generic nickel plated adapter, I got approximately 0.06 ohms, and with a gold plated screw-on adapter off an AKG, I got 0.00 ohms.
