ProtegeManiac
Well TBH the K340s are quite....ummmm...bright...they make T1s sound veiled.I can only use them with old dark recordings("Eighteen"-Alice Cooper)anything with some sparkle the 340s are damn near unbearable
I remember the K340 to be somewhat leaner than the K702 but not bright like that, but then again you might have hyperacusis. I'm fairly sensitive to treble but not as much as most others who are.
Earpad wear could be a factor too, plus the amp - the one I tried out had new pads on it running off a pure class A amp.
Do you have any experience with the original Pioneer Monitor 10?
Digging thru some old threads on here folks say they at least matched,if not beat K702 for soundstage and imaging.
Haven't tried it but I wouldn't just believe it can match the K702 for imaging depth.
EDIT: I just put in an offer on the Pioneers,pretty cheap..if they dont float my boat I will prolly end up going with The Stax option.Any particular Stax that wont break the bank I should be looking for?
Just make sure to get newer earpads for it at least before deciding you don't like them, at least if they don't come with fresh enough pads.
