Does socketing components affect quality?
May 28, 2005 at 10:04 PM Post #16 of 21
Originally Posted by PinkFloyd
So "Analogue Devices" are talking bollocks when they say:
"IC sockets should be avoided, since their increased interlead capacitance can degrade the bandwidth of the device."
No, I didn't say that. Datasheets often make remarks of a general nature and not specific to audio circuits. Opamps are used in applications where bandwidth and speed requirements are far higher than in audio. Excessive bandwidth is actually a liability rather than a benefit in audio, and this is why many circuits employ bandwidth-limiting compensation capacitors. When operating in this fashion, using a socket should not be a problem, unless the pcb is poorly designed and things are already at the verge of instability.
May 28, 2005 at 10:35 PM Post #18 of 21
Could you expand on this if possible?
Bandwidth in excess of several hundred KHz to 1MHz range is not necessary in audio, because audio signals live in a range far below that and we can't hear any higher. A circuit with too much bandwidth is susceptible to stability concerns, RFI, and myriad other sundry issues, which would degrade performance within the audio band. A good amp design should have enough bandwidth so that there is no roll off in response or phase shift within the audio band, and that musical signals cannot be slew-limited in any way, but not more than that.
EDIT: The "several hundred KHz to 1MHz" bandwidth remark I made refers to the frequency response of the amp. This is not to be confused with the GBP (gain-bandwidth product) spec of opamps and transistors. The GBP spec is the frequency at which the device stops being an amplifier. Since real amplifiers have gain, we need a GBP higher than the intended frequency response by at least the amount of gain. Take, for example, a gain = 10x amp, and our target frequency response is up to 10x the top of the audio range (200KHz), then a device with GBP of at least 2MHz should be used. This is a bare minimum and I would be happier with a device that has GBP of 20MHz. Devices that have even higher GBP would be of academic interest and of dubious real-world benefit.
May 29, 2005 at 12:20 PM Post #19 of 21
Okay - so i take it that socketing transistors etc does not affect sound quality, i just have to watch out for mechanical problems such as oxidisation which will affect sound quality.
Thanks for that guys
Rob.
May 29, 2005 at 3:04 PM Post #21 of 21
One other consideration is that socketing will add some thermal drift which could result in DC offset changes.
I don't think that will be an issue for the Dynalo though, because there is a DC servo to correct for drift due to heating of the transistors (which has a bigger effect on DC offset).
