cooperpwc
- Nov 20, 2006
If you are routing the sound back through your TV, it seems very unlikely to me that an external DAC will have an useful affect at all. If you go with an external DAC, you need to go for external ampliufication too. The Total Bithead, the MictStack (DAC+amp), and the Meier-Audio Corda Aria that MaloS refers to would all qualify. The advantage of the microstack is that you would also have the coaxial input. If DVDs are your focus, that does make some sense. It also costs dollars.
Anyone: perhaps there are less expensive solutions out there for a DAC with coaxial input? The MicroDAC is $300.
Originally Posted by lerio /img/forum/go_quote.gif I don't need a Amp for listen to my DVD as the sound go through TV and have enough power for my Grado sr60 But if i buy a DAC with optical/coaxial input for listen to my DVD you're right i should buy one with external AC power-supply About using MicroDAC & MicroAmp i prefer buy 1 combo who can do both rather then buy 2 units The question is the optical/coaxial input for listen directly from my DVD coaxial output will give a real better difference conpare to what i can ear now when i listen it on the headphone of my TV ? ,same as i one i found between my Hi Fi or DVD compare to my PC (Asus A8N-SLI) ? |
