smokey
- Feb 19, 2002
Just received a Dodd Audio headphone amplifier from Gary Dodd.
http://www.doddaudio.biz/ncommerce/p.../headphone.htm
I ordered it with NOS Western Electric 417A tubes, and a DACT volume control. Total price, delivered to my door was a little north of $900. The standard version goes for $650.
I don't pretend to understand the circuitry, but as near as I can tell this is a very simple amp. Just the transformer, a resistor, and the tube in each channel. No caps in the signal path. There are three headphone jacks, one for 32 ohm phones, one for 300 ohm phones, and one for 600 ohm phones. I would guess the difference between each would be resistor value. However, my speciality is a small portion of the US Tax code, not electronics, so I could be wrong.
I've got to say that at first listen this is one fine amp. It reminds me a lot of my tuberolled Wheatfield HA-2, except that the Dodd is sweeter and has quite a bit more inner detail. I am hearing low voices and notes that escape my notice with the Wheatfield.
I am hearing a little bit of a very low level hum, that is independent of volume, and is so low that it is unnoticible except between songs, when the air conditioning is off. (Its about 105 degrees here today, so the AC is functioning quite frequently.) Mr. Dodd tells me this will likely go away as the tubes break-in. However, I'll be playing with interconnects, power cords, and location to see if it makes a difference.
I've used the AT 3000 and the R-10 so far, and I can already tell this is a Sony loving amp. Its not even close at this point.
If anyone is interested, I'll update later as I get more time on the amp.
