Soymilk
- Jan 5, 2006
wasnt really sure if this should go in the dac forum or here.
i'm looking for a replacement for my desktop, i had an x-fi elite pro that bit the dust. seeing as last time i really looked into audio stuff was when the x-fi cards were the hot new thing, i wanted to check in to see if the landscape had changed. for a similar budget (<$100), is there any usb dac that would be better suited than simply getting a soundblaster z? i still have my headphone amp, and i know the soundblaster is supposed to have one built in; my thought was if i can spend the full budget on just a dac instead of a dac/amp combo of sorts, maybe i can get better value? i remember last time i looked (~10 years or so ago) the general consensus was that dacs were very poor at positional audio though. is that still the case? if gaming is fairly heavily considered, would i still be best off just getting a soundblaster z?
my usage split would be roughly 50/50 between games and everything else.
if anyone's curious or makes any difference, the rest of the setup is:
speakers: swan m10 (just ordered, my klipsch promedia 2.1's recently died too)
headphones: ppa v2 -> dt770pro80 / q701
thanks!
thanks!
