DJ XtAzY
- Apr 2, 2012
So I bought my first can, which is the Ultrasone Pro 900, since I want to see how much of a difference coming from IEM. I also own Audio Technica CKS77 and Future Sonic MG7 IEMs, so you know I'm a basshead. I also love a huge soundstage so I was curious whether this headphone will give me a wider soundstage.
Now I use my cans primary on my desktop and iPhone 5. There are times I find the treble a bit harsh, so I use equalizer apps (such as eQU or Denon's equ) on the AppStore to tweak the high ends.
Anyways I'll be buying Creative SoundBlaster ZXR soon anyways, so I'm not worried about my desktop. I never own a portable amp before so I'm especially a noob at that. The sound coming from the iPhone is loud enough and enough bass due to EQ apps. Does an amp makes it even better? And yes I did search old threads, but most are related to older iphones, which probably didn't have the potential to drive this can. If so, which one would you recommend?
