bigshot
Pink Floyd makes me fart too. But not as much as Yes.
I once had a subwoofer that farted during Pink Floyd's "Breathe" intro. I don't mean it sounded bloated or unclean, I mean it literally kept farting. Horrifically bad port noise issue. Sent it back.
Well, the higher-end HT receivers are in fact better. Larger power supplies, more clean power, and better specs in terms of actual audio performance. Higher quality in general; you get what you pay for when it comes to HT receivers. And yes, some of us care about these things, bigshot.
And it's not the audio performance that becomes antiquated. It's all the useless functionality that they try to integrate into the damn chassis. And you always notice that that's the stuff they try to sell you on, so that in a few years, you have to trash your old one and they can sell you on the next tech buzzwords.
My point is, get a separate 5-channel (or however many channels you want) amplifier, and get a HT processor/preamp to go with it. You can upgrade the processor in a few years if you really want support for the next magic format or whatever. That's the better way to do it IMO.
Modern electronics performs to specifications far beyond the equipment of thirty years ago. It's much better to get current midrange solid state equipment and just replace it when it burns out. Time marches on.
What is it with people on this site accusing others of being trolls... bigshot isn't trolling, he simply said something you don't agree with. He may be wrong, but he's not a troll.
FWIW, there were just a few things not known in the 1970s that are well known now, like dynamic headroom, stability into reactive loads, and they were just discovering TIM.
Perhaps a better way of putting that is that the so-called "high end" audio industry was re-discovering things that had been known sometimes decades earlier.
se
I know you are smarter than that, troll.![]()
Sorry, can't go there. For example, the old tube amps may have had more dynamic headroom but it wasn't by design, it was because a spongy high voltage power supply was cheaper than a stiffly regulated one. The fact that the spongy supply contributed to dynamic headroom was beside the fact. When stiff low voltage, high current power supplies showed up in solid state amps that clipped like hitting a brick wall, it took several years before the soft high(er) voltage supply was recognized as an advantage, even then the motivation was economic. (Apt 1 power amp). Just because in the evolution of tech things sometimes get worse before getting better doesn't mean knowledge is lost, it's learning to apply all of it under new design criteria.
Way, way out of line. Even for Head-Fi. Bigshot's comments, even if you disagree with them, did not warrant that kind of attack
You know what? I lived through the 1970s, and cut my teeth as a hifi nut on the equipment you love so much. My brother has a Macintosh system he bought back then, and he still has it. Does it sound cleaner than my midrange Yamaha receiver? Nope. Are the features better? Not even close. Does his system sound better than mine? No way. My system sounds light years better because I have an onboard parametric equalizer, DSP processing, 5:1 sound and direct HDMI inputs. His system takes up a whole closet and he has to leave the door open because it gets hot. Mine fits on the end of a table.
Now if you're thrift store shopping and you find a nice old Marantz, that's fine. It's fun to find ways to put other people's castoffs to use. But don't kid yourself. Old amps are not better than current ones. Speakers? Yes. Old 1970s cabinet speakers sound MUCH better than the tiny satellite systems and outer space shaped high end speakers. They're a lot cheaper too.
Back in the 70s, I dreamed of amps with perfect specs. I wished I could have multichannel sound like at the movie theater, I imagined a time when music didn't have surface noise and I could fit a whole room full of records in my pocket. When I could easily record, edit and copy without generation loss. And I would be able to find a specific song from among thousands and play it without digging through records and cuing it up.
I've got it all now, and I don't want to go back.
