I have a ZMF Atrium Open incoming shortly, and am curious about preferred settings with the Stellaris for those that have it. It’s supposed to like high impedance as it’s 300 ohm, so do you use the IEC 120 ohm output impedance, or something lower like 8 ohm? It’s going to have a balanced cable so I’ll be using that output. While I’ll use the XLR, do you use balanced drive or single ended drive with it? I realize this is basically a subjective question, and I’ll listen to both, but am curious what people’s experience are with what works best.
