BRBJackson
- Aug 30, 2004
The wire leads on the LED for my old Musical Fidelity X10-D have broken off, so I no longer have any power indication. Need to replace it, but it just appears to be epoxied in place, so I'm thinking I need to:
- Drill away the existing LED until a clean metal hole is created
- Measure the voltage and current of the cct board's LED output
- Source an appropriate voltage/current draw/size replacement
- Glue the new one in place and connect
So given that I am an electronics moron, that means dumb questions
- How specifically do I measure the output from the cct board with a multimeter? What am I looking for?
- What are some good sources for replacement round LED's that don't specifically come with panel mounting hardware?
- Are LED ratings based on voltage and current draw, or are there other factors?
- Has anyone worked with LED's on the old MF X-Can form factor? Any shortcuts or advice?
Thanks in advance!
Thanks in advance!
