stallion11msu
- Apr 29, 2002
In regards to DIY foamies, how could I go about putting the hole into a solid foam earplug so they'll fit the plastic tube of real ety foamies? Simply punching a hole in the foam doesn't work, as the foam bunches up around one point and won't compress...Honestly, don't laugh, this is harder than it sounds...
