Hi all, I wonder if someone can direct me to a place where I can order the replacement battery for QP2R.
Thanks in advance.
PS. I have contacted Questyle with no luck.
Thanks in advance.
Thank you and your help is appreciated. The problem is with the connector. I think any similar size with similar specs battery sourcing should be ok and you are correct about the Q1PR battery it’s just the connector is very odd shape. Please see photos.See if it takes the same battery as the QP1R. That one is available as a knock off on AliExpress.
May I ask how did you open the QP2R, please? also, have you got any luck getting the battery replacement? Thank you in advance.Hi all, I wonder if someone can direct me to a place where I can order the replacement battery for QP2R.
Thanks in advance.
May I ask you to forward the possibility for getting the replacement battery for QP2R also, please? Thank you.I have forwarded the inquiry to few AliExpress sellers. Fingers crossed!
