MH79
- Oct 16, 2007
Inspired after seeing the dual balanced cmoy amp thread, and finally wrapping my head around how balanced headphones actually work (this site really helped: http://www.headphone.com/products/fa...vs-unbalanced/ ), I think I may have a go at running my HD-580 in a balanced set up (once I get all the bits)
Now, would it be possible to just buy a HD-650 cable, and modify it for balanced operation? I'd only really end up using the plugs from the HD-650 really (it's a shame you can't get the plugs seperately for a reasonable cost).
Also, is there any reason to use XLR plugs apart from durability? I was planning on using 1/4" jacks instead.
