keiron99
- Jan 6, 2004
I posted previously about how to add remote volume to my Stax energiser, to enable volume control from the other side of the room (I have multiple seating positions, and will be getting / making an extension cable). I have not found a satisfactory solution.
My proposed solution is, rather than connect my DAC directly to the energiser, to run it to my preamp, then the variable line outs of that into my energiser, thus allowing remote volume control via the preamp.
The only thing nagging me about this is having 2 volume controls in circuit. Should this concern me? If it's easy to do, I'm prepared to snip and solder inside my energiser to disable the volume control. Can anyone advise whether this is sensible or not and if it is, how I'd go about doing it?
Thanks
Thanks
