JonathanHF
- May 30, 2007
Recently I found that there were a lot of noise coming from my PC speakers,
and guitar amp. It makes high pitched, and bug like sound every second.
Later I found that the noise is caused by my Toshiba laptop.
The noise appears when the power is supplied by AC, and disappears when
the laptop is ran on battery. I'm certain the problem is not caused by the ground loop because, first, the cheater plug does not reduce the noise, second, the noise is not the low pitched sound the happens when there're ground loop issues.
From my research the noise is caused by the poor quality of the power supply as those manufacturers have been costing down everything these days.
I cannot really blame on Toshiba since other companies like HP, Dell, and Lenovo all have this issue.
I've done a lot of research in the past few days just to find a solution, but can't seem to find a solid solution to the problem.
I heard the isolation transformers will work but they are too expensive, and I have no past experiences with those.
Please help me with this problem as this has taken away my sleep for the past few days.
