chee006
- Aug 28, 2013
My current DAC is a Aune X1 Pro DAC which could play up to 24/96khz through USB, However my build-in PC sound card can play up to 24bit/192khz. The problem is that I have just found out when I am using direct sound on foo2k for my DAC it can play 192khz when it should not be able to. But when I change to ASIO it says it can't play 192khz which is what my DAC iss suppose to do.
This made me think if the sound on my Windows8.1 when using direct sound would still somehow go though my PC sound card but still uses my DAC somehow since there is no difference in sound quality when switching from ASIO to Direct Sound for my DAC.
Hope you guys can figure this out, thanks!
