droopdog7
Not sure how many people out there still using iTunes to stream Apple Music but I recently stumbled upon a solution to this weird quirk I encountered when playing music on my PC (Windows 10) in iTunes. It's sorta hard to explain, and there may be multiple triggers, but here goes.
The general idea is that I would often have to restart iTunes to get sound. Sometimes it happened when I tried switching sound output source (i.e., I needed to restart iTunes). Sometimes it seemed that I needed to start iTunes or my amp in a particular order, though I never quite figured it out. The most obvious thing though was this; if I clicked play in iTunes before I started my amp, I was doomed. First, the song wouldn't actually play. If I turned on my amp, it wouldn't play. Had to always restart iTunes in that case. Alternatively, if I turned on my amp and then hit play, I was mostly good.
So, messing around with the settings today and it seems I located a fix. If I change from Windows Audio Session to Direct sound, it seems I no longer have to concern myself with which order I start my amp or iTunes or whatever. If I start a song in iTunes before turning on my amp, the song actually plays (albeit I can't hear it). If I turn on my amp next I get sound. Crazy, I know.
So two questions; what the heck is going on? Second, am I suffering from "worse quality" in Direct Sound (or vise versa)? I don't have proper tools to do a real A/B comp, and the fact that I have to restart itunes anytime switch these two options makes it even harder to compare. The logical person in me doesn't really hear a difference. The Type A person in me just wants to know.
Bonus question; where am I supposed to set the bit rate and sample audio? I just put them both at the highest setting.
